rob c
SERIEL CABLE
would like toknow if longer seriel cable can be used cable supplied is to short for my location inst says to only use supplied cable is not fesible to use this one have sent to tech support no response just got machine  :-
Tech support is one man, a mighty man named Kenimes. He will get back to you but in the meantime me and my fellow family members here will try to assist you. Using a longer cable shouldn't be much of a problem. How much longer are you talking?
I got my Copam on approx 16' of usb cable & it works fine
Got my Roland on a 25' parallel cable with no issues
Make sure your connections are good and secure for machine and computer and as long as you aren't trying to stretch it 50', you should be okay.
For my main cutter I use a 6 foot serial with a 10 foot extension. No problems at all.
THANK FOR THE ANWSER TO MY QUESTION NEEDED TO RUN APPX 14 FT  THANKS FOR THE HELP AM SUR WHILE LEARING SYSTEM WILL NEED MORE OFF TO GET CABLE
