stanger 3 Posted January 16, 2014 The good news, I'm getting better. But I still have questions. When I take a regular picture I find on google or whereever or a decal I want to try and make, it put it into Inkscape and convert it to a vector. What is happening is that it's cutting an outline and I'm guessing it's because of the shading on the image. So, for an image, it's making 2 cuts around the outer edge. When I blew up the picture I see this. Is this the problem and if so how do I fix it? Share this post Link to post Share on other sites
stanger 3 Posted January 16, 2014 here's a better shot of what I'm talking about Share this post Link to post Share on other sites
constricted 27 Posted January 16, 2014 looks like its creating paths for the solid part of the image as well as the shading on the image.. i don't use inkscape, but what you want to do is merge the paths. also after looking at your cuts, your also going to want to play with the nodes so the outline isn't as jagged because of the pixelation around the edges on the image you are converting. Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 16, 2014 Are you using Edge Detection when you do your trace? If so switch to Brightness cutoff, that should get you the results you're after. I usually change the threashold to .55 but it can vary from image to image. Just play around and see what works best. Share this post Link to post Share on other sites
stanger 3 Posted January 16, 2014 What I didn't do was change it to "2" colors for just black and white. After I did that it looked much better. Thanks for the help!! Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 16, 2014 I don't use Inkscape much either but I do have a copy on my work (other job) computer. If you go to the "view" tab and then hover over the "display mode" then choose "outline" it will remove the colors so you can see what your cutter is going to see. You can remove the lines you don't want or select both and weld them together by selecting "union" from the paths menu or using the keystroke "Ctrl++" I don't know why it's tracing both, could be a setting in the trace image section but I am not familiar enough to help out on that one. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted January 16, 2014 Have your tried to trace it right in sure cuts? Very powerful trace program even if the rest of it is somewhat lacking. Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 16, 2014 What I didn't do was change it to "2" colors for just black and white. After I did that it looked much better. Thanks for the help!! I'd still suggest trying the Brightness cutoff option. The colors number only matters if you also click the Color Quantization button. Share this post Link to post Share on other sites
skarekrow 1,842 Posted January 16, 2014 Often pictures have to be massaged before hand in a raster based program like photoshop. In this case sharpening the contrast and/or posterizing the im to just 2 colors would eliminate the issue. (as well as some measures in Inkscape... as you found) 2 Share this post Link to post Share on other sites
stanger 3 Posted January 17, 2014 thanks everybody for the help, I learned several new things now. When I was looking at it in photoshop, the outline effect was set so that's what was messing me up Share this post Link to post Share on other sites
