MotivatedNY 0 Posted December 29, 2013 The right side of my image will not stay clean even if its the same points as the left. This is hard to explain in text but easy to see in the pictures. When mirroring the image and uploading them at the same time the left side is perfect but the right side is bad has any one ever seen this before. perfect in illustrator, bad in SCA Share this post Link to post Share on other sites
BCOJdecals 39 Posted December 29, 2013 The right side of my image will not stay clean even if its the same points as the left. This is hard to explain in text but easy to see in the pictures. When mirroring the image and uploading them at the same time the left side is perfect but the right side is bad has any one ever seen this before. perfect in illustrator, bad in SCA Haven't really messed with SCAL, but I did notice something...probably nothing, though...but the pic on the right seems a little (albeit very little) bigger than the one on the left...might be an extra layer. See my pic...the spaces in the one on the right are definitely bigger, even in the pic where the two are welded. Share this post Link to post Share on other sites
maddog 12 Posted December 29, 2013 Had some free time , thought I might try and help, here is what I came out with, could use a bit more cleaning up maybe. 1 Share this post Link to post Share on other sites
Wildgoose 4,085 Posted December 31, 2013 perfect in illustrator, bad in SCA This is probably a dumb question but do you have illustrator? If so why are you trying to draw in SCALP? Waste of time, assuming you have access to AI. Share this post Link to post Share on other sites
MotivatedNY 0 Posted January 2, 2014 I imported it into sure cuts alot from Ai and it does it when it is imported. Share this post Link to post Share on other sites
Wildgoose 4,085 Posted January 2, 2014 Upload the AI file here on the board and I'll see if I can help figure it out. Share this post Link to post Share on other sites
