tysan
boat vinyl
On 6/3/2018 at 2:05 AM, cinner74 said:
Can you tell me what app tape you used and also if you did a wet or dry application? Thanks in advance!
Not OP, but I have found Rtape conform (medium tack) to be the best for pretty much any pressure sensitive media. It does not work well with Air release technologies. Also i would suggest a wet application for applying 651 as a color change piece or large chunk like he has makes it much more forgiving.
Edit: Don't forget when wet applying and using mask, to not use clear mask for wet installs. Also if your mask is gripping the vinyl before its fully dried, spray app fluid on the mask and let sit, this will allow the masks' adhesive to become weaker.
Edited by gmorrell
Info
