myvinylcreations.net 3 Posted December 2, 2013 hi, I have no idea on how to make a border on an image using sure cuts A lot Pro. could someone please tell me what do I have to do to get border? Thanks Share this post Link to post Share on other sites
BigDon 2 Posted December 2, 2013 If you are talking about a shadow border - Select your graphic; Go to the appearance tab; Select shadow and then set the offset (the distance you want the shadow to extend from your graphic); Set your fill and stroke color; Make sure the line style is set to your preference; Set your cut line type to your preference (cut line, draw, or draw and cut) There you have a border surrounding your graphic. Share this post Link to post Share on other sites
myvinylcreations.net 3 Posted December 6, 2013 If you are talking about a shadow border - Select your graphic; Go to the appearance tab; Select shadow and then set the offset (the distance you want the shadow to extend from your graphic); Set your fill and stroke color; Make sure the line style is set to your preference; Set your cut line type to your preference (cut line, draw, or draw and cut) There you have a border surrounding your graphic. I am sorry i meant how do i make an outline? Share this post Link to post Share on other sites
slice&dice 2,450 Posted December 6, 2013 In SignBlazer, there is a command within the Draw menu, "Border" (and right-clicking in the workspace provides a dialogue box with parameters and specifications of that border, including rounded corners or multiple-line borders) Hopefully in SCAL there is a similar option, I don't know. Share this post Link to post Share on other sites
myvinylcreations.net 3 Posted December 6, 2013 In SignBlazer, there is a command within the Draw menu, "Border" (and right-clicking in the workspace provides a dialogue box with parameters and specifications of that border, including rounded corners or multiple-line borders) Hopefully in SCAL there is a similar option, I don't know. i think iam end up doing the border or outlines on signblazer. SCAL but lacks simple function that I could easily do on signblazer. 1 Share this post Link to post Share on other sites
dirttrackin280h 33 Posted December 7, 2013 Is this what you're after? Same method applies to doing text and any other image. Click link for video: http://smg.photobucket.com/user/dirttrackin280h/media/2013-12-06172448_zpsb64f71bc.mp4.html Share this post Link to post Share on other sites
myvinylcreations.net 3 Posted December 10, 2013 Is this what you're after? Same method applies to doing text and any other image. Click link for video: http://smg.photobucket.com/user/dirttrackin280h/media/2013-12-06172448_zpsb64f71bc.mp4.html you are the man. it worked thank you!! Share this post Link to post Share on other sites
