cod543
Blade holder isnt coming down enough for blade to touch vinyl
I recently bought my SC cutter plotter, and first the black cartridge was off its hinges so i put all 3 wheels back on the tracks. So thats not a problem anymore. Yet, now the blade holder doesnt come down enough to hit the vinyl, meaning that theres still space between the vinyl and the blade. the blade is out enough however. I dont know if i got a small blade holder or if there is a malfunction anybody have any ideas on how to fix this problem?
Check and see if the holder is all the way down in it's clamp . If not tight , sometimes they push up some .
I actually got all three wheels in the track last night. so it works smoothly now. its just the blade has space between the vinyl
this is how you set your blade correctly:
My blade is in correctly, less than the width of a credit card. My problem is: the blade doesnt reach the vinyl.
The blade holder sits within the clamp (there's a slot to accept the blade holder).
In other words, it isn't designed to rest with the flange of the blade holder sitting on top of the clamp assembly, but rather nestled inside of it.
post-21408-0-47561300-1382890195_thumb.j
He wouldn't be the first person to make that mistake,either.
HA!  I did the exact same thing when I got my cutter a couple weeks ago.  I bet your blade holder looks like this right now...
Grab the blade holder and pull up...I bet it slides right out.
This is how it should look....
Hope this helps...
Great illustrations for what I tried to indicate, karkess.
Those close-up pix are exactly what the doctor ordered.
Gold star for you.
LOL!  Took me a bit to figure why my machine wasn't working.  Can I wear the star on my forehead?
Hope this helps...
My blade holder looks just like your first pic can't get it in the slot where it is supposed to be. but have used my cutter for a couple of years now. if i put it in the grove can't get anything under the blade at all mine is a MH.
