matty123 0 Posted October 18, 2013 hi all this is my first time on here hope someone can help im trying to cut out the writing that is joined together but when i export it to signcut it cuts out bits i dont want it to is there a fix to this atal ? i have added photos to show what i mean Share this post Link to post Share on other sites
darcshadow 1,395 Posted October 18, 2013 Did you try doing a search for this on here? Common problem people have and it's been explained several times. You need to convert your text to paths then weld/union them all together. Share this post Link to post Share on other sites
rdrgrafix2 30 Posted October 18, 2013 should be a weld function under objects tab 1 Share this post Link to post Share on other sites
bikemike 690 Posted October 18, 2013 Not to sure about signcut but I just weld without the convert. But yes, weld will fix that right up. 1 Share this post Link to post Share on other sites
matty123 0 Posted October 18, 2013 thankyou for all your help guys all done Share this post Link to post Share on other sites
bossman696 28 Posted October 26, 2013 I learned something new. I only used Illustrator for tracing images. I have designed in Indesign for years and feel much more comfortable there. I export as a High res .jpeg and then open in Illustrator to trace and send to sign cut. I really need to expand a bit and try new things. Share this post Link to post Share on other sites
Wildgoose 4,108 Posted October 27, 2013 I learned something new. I only used Illustrator for tracing images. I have designed in Indesign for years and feel much more comfortable there. I export as a High res .jpeg and then open in Illustrator to trace and send to sign cut. I really need to expand a bit and try new things. Yeah buddy! A little time spent learning the tricks will yield a lot cleaner results than auto traces. Downside to Adobe is the substantial learning curve at the start but if you are already good with InDesign I would think the transition wouldn't be as bad as a total newbie. Share this post Link to post Share on other sites
bossman696 28 Posted October 28, 2013 Yeah buddy! A little time spent learning the tricks will yield a lot cleaner results than auto traces. Downside to Adobe is the substantial learning curve at the start but if you are already good with InDesign I would think the transition wouldn't be as bad as a total newbie. This is true. But just to be safe, it may be time to renew that old Lynda.com subscription for a refresher! Share this post Link to post Share on other sites
