troyr 4 Posted October 10, 2013 does anyone know how to change a pdf file to be able to vectorise? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 10, 2013 What software are you using? Some pdf are vector so it's worth checking. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 10, 2013 Sorry I didn't even see the Signblazer at the top. It's been a long day. Can't help you I haven't used Signblazer in years but I'm sure help will be along shortly Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 11, 2013 Here'e what I would do -- 1. Open the .pdf file in your Acrobat Viewer 2. Select (All) 2. Copy 3. Paste into Inkscape 4. Convert (Path/Tracebitmap) 5. Delete bitmap -- retain the vector 6. Copy 7. Paste into Signblazer Share this post Link to post Share on other sites
Jay2703 704 Posted October 11, 2013 you can open a .pdf with Inkscape. then just save it out as an .eps file. Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 14, 2013 Not all PDF files are vectors though. Open it with Inkscape and try to node edit it. If you can then just save as EPS, if you can't you'll need to trace it and create a vector. Share this post Link to post Share on other sites
caroline19 1 Posted December 31, 2013 Using a PDF document converting control, you are able to convert PDF file to vector images, like SVG. Here is a detailed guide for changing PDF to SVG vector image. Share this post Link to post Share on other sites
BearlyRich 167 Posted December 31, 2013 Using a PDF document converting control, you are able to convert PDF file to vector images, like SVG. Here is a detailed guide for changing PDF to SVG vector image. This is certainly NOT a "detailed guide" but IS a blatant spam advertisement to a commercial product. Unfortunately, it's an API product suited only to dot-net programmers. I doubt you'll drum up any business here for that. Maybe ytou should spam someplace else! Share this post Link to post Share on other sites
Bilster Aussie guy 0 Posted January 11, 2014 I Just use Vector Magic desk top edition works great Share this post Link to post Share on other sites
jparent 0 Posted February 8, 2014 Bring up your pdf file in SB. Click on image, mode then monochrome. After you do that go back to image, vectorize. Drag you monochrome image off and delete. What is left is your vectorized image. Just go in and node edit to clean it up. Share this post Link to post Share on other sites
