katchilds
Starting up a business. Recommendations Graphtec CE6000 24" or Vinyl express Qe 6000
Weed lines are for sissies. If it's too big to do in 1 pc. I use my knife to make my weed lines where needed while it's on the work bench.
AWWWW Snap!
I use them in between lines of text.  I mostly cut heat transfer vinyl which is real stretchy at times and it makes weeding a lot easier.
Take your htv to the heat press. Preheat the platen for 2-3 seconds then lay the htv on there to weed it. You'll be amazed how easy it weeds like that. You make need to adjust the preheat time until you find the happy spot but it works great especially on a swing away press.
