MMPFrankston 0 Posted September 18, 2013 Hello Im having a problem with my VS540. When I send a job from Versaworks it will roll out all the vinyl needed for the print/cut job, then roll it back in to the base point and then start printing and cutting. This has only started in the past 2 weeks so its obviously something somene has changed in the settings. Its not causing any print or cut problems it is just anoying( especially on the larger runs). Has anyone encountered this before and if so how do you stop it? Thanks in advance! Steven Share this post Link to post Share on other sites
