The Elvis Legacy 16 Posted September 11, 2013 I have been using Corel Draw X5 with the CM2 plug in to cut vinyl ever since I got started cutting vinyl (getting close to a year). Im running it on Vista and have had no problems until yesterday. Everytime I try to open up the CM2 plug in, it comes up with a NO ACTIVE DOCUMENT error. I have tried uninstalling CM2 and reinstalling but I have had no success. Has anyone else had this problem? Any known solutions? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 11, 2013 I just did a search of your problem, on the internet, and several people have had it with several different ideas, to fix it. for Corel and Illustrator. I used the keywords : Cutting Master 2 No Active Document error. Put that in the Google search bar. It will take you to other forums, with answers. Sorry best I could come up with. Share this post Link to post Share on other sites
ZerhioMX 2 Posted September 11, 2013 I have this same problem, but it was because CorelDraw wasn't shut properly. Try this: Close both Corel and Cutting Master, then go to the task manager (Ctrl-Shift-Del) and look in the Processes Tab and see if Corel isn't still running, if so, End Process of Corel. Then re-open Corel and Cutting Master and try again. This works for me. 1 Share this post Link to post Share on other sites
The Elvis Legacy 16 Posted September 13, 2013 Thanks guys for your responses. Nothing worked for me. I did try going in under another user name and I had access to corel and CM2 there. I did have to reinstall the drivers for the cutter under that user name but after doing that, I am back up and running again. Perhaps if I uninstalled and reinstalled corel on the user that I was having problems on, that might have worked...but...I CANT FIND MY DISK....aaaaaaaaaaaarrrrrrrrrrrrrrgh! lol Share this post Link to post Share on other sites
freebird1963 11 Posted October 25, 2019 On 9/11/2013 at 7:58 PM, ZerhioMX said: I have this same problem, but it was because CorelDraw wasn't shut properly. Try this: Close both Corel and Cutting Master, then go to the task manager (Ctrl-Shift-Del) and look in the Processes Tab and see if Corel isn't still running, if so, End Process of Corel. Then re-open Corel and Cutting Master and try again. This works for me. 6 Years after the post this solved my issue ! 3 Share this post Link to post Share on other sites
