Bruisbe 19 Posted August 31, 2013 As everyone knows the documentation for the MH series stand is far from anything to brag about. I have been seeing that it is a must to ground your cutter to the stand, however I am missing on where to ground it to and how to do it properly. I am sure I am just over looking it in the documentation, however want to make sure I do it correctly as well. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 31, 2013 From USCUTTER support Grounding can be done by running a copper wire/speaker wire from a screw on the base of the cutter to a point on the stand. Contact points should be metal on metal, which might require you to scrape away some paint. 1 Share this post Link to post Share on other sites
Bruisbe 19 Posted August 31, 2013 +1 for finding a video on USCutters website that showed me how to do this... ....Thank you Google Share this post Link to post Share on other sites
Bruisbe 19 Posted August 31, 2013 From USCUTTER support Grounding can be done by running a copper wire/speaker wire from a screw on the base of the cutter to a point on the stand. Contact points should be metal on metal, which might require you to scrape away some paint. Thank you...I found a video on their website as soon as I posted that topic... 1 Share this post Link to post Share on other sites
