I have the UScutter MH, just hooked it up. My issue is that when the test cut is performed, it works perfectly, only going over the image with one cut. When I attempted to cut a Pitts Steelers logo, it went over that image several times, which messed the entire image up. What am I doing wrong? I'm new to this, so any and all advice is welcomed!
put the image in wire frame and see if there is more than one layer.
Also in some programs there is a setting for the number of passes you want to make
MM64
Is the logo vector, did you trace it? If you grabbed it of the internet it may be a different format.
"Pittsburgh Steelers"
There's the main problem, yes indeed !!!
Go Ravens ---
I like the guy above me.  GO COWBOYS.... lol
I have used several vectors from a few popular sites for the Pittsburgh logo and several of them are in layers.  And will cut multiple times.
What cut software are you using?
If you need another logo that you can test with let me know.   Found one just this morning as someone wanted one.  Its been cut and is in only 1 layer.
Giants hahaha... Go Cowboys
not that it matters but I have that same tattoo on my leg that you are using for you avatar.
