mr.garnica
MH 871- First cut usually good but when i try to re-cut it, it all goes wrong!
So Im running an MH-871 probably a month old, i have a mac and SCALP software. It all looks like its running great except this little problem I've been dealing since i got it. Usually my first cut goes ok, sometimes it starts cutting perfect when all of a sudden the blade runs all the way to the end cutting all my vinyl . I have to restart it and re-set the file then it will cut flawlessly. When the job is done, and ill re-set the blade to the original point to re-cut the same file i go to my computer to do a re-cut and it just cuts random lines
i made this video so you guys can see what im talking about...
http://youtu.be/W5lFpxgjThQ
If you just recently purchased the MH 871 MK2 cutter. new.   it is not Mac compatible.     Says right on the ads
PLEASE NOTE: This vinyl cutter is not compatible with Mac.
USCutter MH Series Vinyl Cutter w/ Sure Cuts A Lot Pro Design & Cut Software The MH Series Vinyl Cutter is available in 14", 28", 34", and 50" sizes. Cutter not Compatible with Mac.
Here it is on the EBAY ad
NEW Vinyl Cutter Best Value Cutting Sign Making Kit USCutter Plotter SALE
MH 871 Vinyl Cutter Value Kit w/ Sure Cuts A Lot Pro - a Design & Cut Software
MAC USERS PLEASE NOTE: This vinyl cutter is not compatible with Mac.
Get it hooked up to a PC running WinXP, and all will be well.
Next...
See that picture of an APPLE on your monitor?  That is the problem...
+1 needs to be on a PC.  XP will be the best.
heck why worry about the hundreds that tried before and couldn't get it to work right - personally I admire your mac can do spirit.  even if it doesn't work right as stated by the seller.   brickwall.gifAngry_Pissed_Off_Emoticon.gif
