sniderman 8 Posted June 19, 2013 can anyone help tell me how to change a svg file to eps file to cut in sign blazer,, NOTE: I have never used inkscape thanx much jeff Share this post Link to post Share on other sites
mb20music 760 Posted June 19, 2013 This is what I use to convert svg to eps http://image.online-convert.com/convert-to-eps 1 Share this post Link to post Share on other sites
Jay2703 704 Posted June 19, 2013 Inkscape will open .svg files and save them as .eps too. www.inkscape.org Share this post Link to post Share on other sites
smokeybearfan 87 Posted June 19, 2013 This is what I use to convert svg to eps http://image.online-convert.com/convert-to-eps Cool site I bookmarked that for future use. Thanks 1 Share this post Link to post Share on other sites
sniderman 8 Posted June 19, 2013 with ink scape do i just save as eps? i could not get that image editor to work. when i try to save as eps in inkscape, I open the eps that it makes in sign blazer but it is not the whole image Share this post Link to post Share on other sites
Jay2703 704 Posted June 19, 2013 Can you post the image here? 1 Share this post Link to post Share on other sites
sleeveofwizzard 104 Posted June 19, 2013 There is a window that pops up once you save a file in EPS. Here is a screen shot of the settings I use for files being cut in SignBlazer. Share this post Link to post Share on other sites
sniderman 8 Posted June 19, 2013 hey ted when i save in inkscape to eps and open in sign blazer the image is all choppy Share this post Link to post Share on other sites
tekcorps 50 Posted June 19, 2013 Post your svg file. Share this post Link to post Share on other sites
sleeveofwizzard 104 Posted June 19, 2013 Choppy? are you sure there is something wrong with it or is it just the low quality image Signblazer produces on the screen? try zooming in and out to see if the choppy look changes. Do your settings match what I posted? Are you selecting "Import" and "use full postscript interpreter"? If you post the eps and svg we can look at them but I understand if its not something you can share. 1 Share this post Link to post Share on other sites
sleeveofwizzard 104 Posted June 19, 2013 For me the most common reason items don't show up in Signblazer is that not all of the graphic is a path or vector. if there is text make sure to select it and convert it to a path before saving the file. This may need to be done with shapes as well. Sometimes you have to un-group things before the program will convert them to a path. There is an indicator at the bottom of the screen that tells you what each object is (path or image) Share this post Link to post Share on other sites
Jay2703 704 Posted June 20, 2013 I replied to your PM with the SignBlazer file. The choppyness is probablly just SignBlazer screen graphics. It should cut fine. 1 Share this post Link to post Share on other sites
sniderman 8 Posted June 20, 2013 thanx guys i will try to cut tomarro and let you guys no how it goes jeff Share this post Link to post Share on other sites
darcshadow 1,626 Posted June 20, 2013 You can also do a select all, copy and paste from Inkscape into SignBlazer and skip the EPS stage. Share this post Link to post Share on other sites
edwin73 0 Posted July 22, 2013 im having trouble putting a eps file in the signblazer software....can any one help me? I go to file and its not in the file area or lets me import or find the file on my computer??? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 22, 2013 Signblazer will only import older .eps files like version 8. Signblazer has not been updated for several years. If you have a design software, like Illustrator then save it back as an older file. version 8.eps. Share this post Link to post Share on other sites
edwin73 0 Posted July 22, 2013 The image is saved in eps file and works in signcut but I can not access it at all in signblazer.... Most of my images where vectorized in inkscape ..... Share this post Link to post Share on other sites
