USMC3225 17 Posted June 10, 2013 I just got a job for quite a few coro signs to promote a detailing business. The shape of the sign has to be a 50's classic like the one they use for their logo. How do you think a router would work to cut multiple coro signs at one time? I looked around and nobody sells blanks in the shape I need. Share this post Link to post Share on other sites
Jay2703 704 Posted June 10, 2013 It should work OK if you have the right feeds, speeds and cutter. You will need to find a way to hold them in place. If these will be mounted with 2 screws, you could use a wood template screwed through a few and cut around it. Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted June 10, 2013 If you have one of these may work better. Not sure but a router as been said would work well if you had a template to guide against. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 10, 2013 I tried router once before and had issues when running along the bias of the flutes. They wanted to shred on me. Share this post Link to post Share on other sites
xpaperman 719 Posted June 11, 2013 I would think, a router would not work well. I have never tried it on coro but have used routers and I can picture disaster....... Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 11, 2013 I wasn't satisfied with the results from the router. If I do it again I may try a bandsaw. Share this post Link to post Share on other sites
dennismc42 12 Posted June 11, 2013 Would say bandsaw.Cut a template out of a couple 1/8 plywood. Clamp the coro between two of them tight, then cut with the band saw. Use the same technique basiclly to cut thin plastic pieces for woodworking laminets Share this post Link to post Share on other sites
USMC3225 17 Posted June 11, 2013 I'm pretty good with the router but would imagine it would leave rough edges that need to be cleaned up. I thought about using a band saw but that is the one thing I don't have as of yet. I have used my router to cut kydex for holsters and just run it over the belt sander to clean the edges. That rotozip tool looks pretty much like a jig saw without the pulling of the blade, may have to look into that thing. Share this post Link to post Share on other sites
OWJones 1,981 Posted June 11, 2013 I'm pretty good with the router but would imagine it would leave rough edges that need to be cleaned up. I thought about using a band saw but that is the one thing I don't have as of yet. I have used my router to cut kydex for holsters and just run it over the belt sander to clean the edges. That rotozip tool looks pretty much like a jig saw without the pulling of the blade, may have to look into that thing. A scroll saw should work on coroplast as well, and is cheaper than a band saw. I know a lot of people don't like Harbor Freight, but I bought a scroll saw from them 10-11 years ago and it's still working - the one they have on their site now is $68 + $7 for S&H. If you were going to make intricately carved wooden clocks or something, I'd go with a more expensive version, but for cutting coroplast, this one should more than suffice. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 11, 2013 Harbor freight store is 30 minutes from me, Haven't been in a while maybe next weekend. Share this post Link to post Share on other sites
xpaperman 719 Posted June 11, 2013 I think you can create an account online with them, then you get coupons etc. via email. Makes the trip so much more worth it. Share this post Link to post Share on other sites
sleeveofwizzard 104 Posted June 11, 2013 I would think a hand held jig saw and a scroll saw would work best. Home depot has Jig saws starting at $20. The rotozips are pretty cool, I have used them on sheetrock hundreds of times and they work great for that . . . Share this post Link to post Share on other sites
USMC3225 17 Posted June 11, 2013 Harbor Freight is about an hour from me... like everything else lol... but I have tons of tools from them. I buy most of my bigger power tools from sears bc I like craftsman tools but if Im not going to be using it hard of its a good enough deal I will buy from Harbor Freight especially hand tools bc they have a lifetime warranty and are cheap. I might have to hit them up for a cheap band saw. I wont use it much but every now and again I do wish I had one. Maybe a scroll saw as well. Share this post Link to post Share on other sites
OWJones 1,981 Posted June 11, 2013 Harbor Freight is about an hour from me... like everything else lol... but I have tons of tools from them. I buy most of my bigger power tools from sears bc I like craftsman tools but if Im not going to be using it hard of its a good enough deal I will buy from Exactly - I would never rely on a Harbor Freight Tools power tool if it's use was required for my primary source of income, but for those tools that you only use once in a while, there isn't a need to spend the money for a Dewalt or Delta. 1 Share this post Link to post Share on other sites
dennismc42 12 Posted June 11, 2013 My son one day shopping in there with me said it best..."They sell tools and tool shaped objects, the hard part is telling the difference" 5 Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted June 12, 2013 I second OWjones with the scroll saw. Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 12, 2013 I have a rotozip, it's quite hard to follow along lines with it, because it wants to ROTATE all the time. My main use for the rotozip is to slice through acrylic panels (using a special bit, called a "Sabrecut" especially for hard plastics). This type of hand-held scroll saw seems cool -- Share this post Link to post Share on other sites
