gsxr600 1 Posted May 29, 2013 I Searched the site and found www.gasketsondemand.com And was wondering how to download the files so I could cut them?? Im using sure cuts alot pro, and ive downloaded the free version of corel draw... when I click download and save or open it tries to open the file in adobe and says its not a supported file type.. Im not the smartest with computers just trying to teach myself with ALOT of help on here.. Thanks Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 29, 2013 Right click on the file and select open with, choose what program you want to use. Share this post Link to post Share on other sites
gsxr600 1 Posted May 29, 2013 Thanks for the help, I tried in corel and it says format not supported??? Im sorry if these are stupid questions but I really am out of my elements on with this stuff. What do you recommend I open the file with??? thanks, Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 29, 2013 what is the file type? "gasket_file.???" Share this post Link to post Share on other sites
gsxr600 1 Posted May 29, 2013 GD1 File (.gd1) Does this look right? I found this in the properties Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 29, 2013 You will need Gerber proprietary software to open that.... I can't help with it. Sorry. From http://www.file-extensions.org/gd1-file-extension "The GD1 file extension is generally related to one of the many Gerber formats. A Gerber File is a file format used by printed circuit board manufacturing machines to layout electrical connections such as traces, vias, and pads (the component footprints on the PCB). In addition, the file contains information for drilling, and milling the completed circuit board." What it probably boils down to is your gonna have to pay someone to use those gasket templates.... Share this post Link to post Share on other sites
gsxr600 1 Posted May 29, 2013 ahhh gotya Thanks so much for your time I would have never figured that out lol Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 29, 2013 Not a problem. It's prolly gonna be easier to just order up the gasket you need. (if it's just the one) and when in a tight spot, I've cut a few with a razor knife in the past. Good luck with it. Share this post Link to post Share on other sites
USC60406 2 Posted May 29, 2013 What about ctrl+print screen, then insert into MS paint or similar program, crop, then save as jpeg? Share this post Link to post Share on other sites
gsxr600 1 Posted May 29, 2013 Well I do alot of work on bikes and it would be really nice to be able to make my own. Im gonna call the company today and see how much the program is or see if they could send me a file just to see if my cutter will even cut the gasket material. Share this post Link to post Share on other sites
