livinloudgraphics 39 Posted May 22, 2013 im looking to stock up on alumicore if im not mistaking that is what it is. used for outdoor signs and such been looking around and just dont know where to turn for this stuff thanks Share this post Link to post Share on other sites
SignJunky 10 Posted May 22, 2013 Have you checked with Grimco and Southeastern Sign Supply? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 22, 2013 Alumacore is up there in price. Personally I use way more max-metal with excellent results. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 22, 2013 I prefer diabond to alumicore diabond is an aluminum plastic composite easy to cut , shape and install plus being fairly light. I belive the max metal mentioned above may be the same . Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 22, 2013 Max metal, dibond, cbond depends on who you buy it from but same stuff. I took down an alumacore sign that was up for around 6 years and you could squeeze between thumb and forefinger and crush the center core. It's just coroplast in the middle and I don't think it's very UV stable. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 22, 2013 Max metal, dibond, cbond depends on who you buy it from but same stuff. I took down an alumacore sign that was up for around 6 years and you could squeeze between thumb and forefinger and crush the center core. OPIt's just coroplast in the middle and I don't think it's very UV stable. The thing I don't like about alumacore is how easy the edges tear up and on installs you have to be very careful not to dimple it with your screws . 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 22, 2013 Not to mention twice the price... Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 23, 2013 My GRIMCO catalogue lists the two-sided 3 mm. white MaxMetal (AKA diBond) sheets at around $65 (4x8) and they also supply the single-side white (mill-finished backing) material for about $55. The Alumacor 5mm. is $100. (and you also have to put a trim cap over each of the open-flute 4' sides) Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 23, 2013 1 sided is up to $62.95. Gets more expensive every time I price it. Before they absorbed my supplier I was paying $38 2 sided, now it's $67.95. Alumacore is showing for $118.95 and 8' pc. of trim cap is $5.95. Share this post Link to post Share on other sites
