madmike55 0 Posted May 15, 2013 My cutter is messing up on a cut that 17 inches long, it will cut half of it the cut a square around it then drag the blade across it then it will do the same on the second half. I use signcut and I also have a keyspan. Im new to cutting so it is probably something simple im doing Thanks for any help Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 15, 2013 1 of two things come to mind - lack of meemory in cutter depending on amount of nodes or static becuase the stand is not grounded to the cutter - static builds in the stand/vinyl and discharges thru the cutter head Share this post Link to post Share on other sites
madmike55 0 Posted May 15, 2013 I have the cutter grounded to the stand, I don't know about the memory just what ever it comes with. Is there a way to clear the memory or do I need to add more? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 15, 2013 some turn the cutter off after each cut - more memory is abailable here http://www.uscutter.com/4MB-Memory-Chip-for-USCutter-MH-Series-Vinyl-Cutters-Non-MK2-ONLY I would also switch to a serial connection via a card in your desktop - keyspan adapter if laptop with a null modem serial cable Share this post Link to post Share on other sites
