Ericjgidney
Cutter Issues?
I could use someones help. I usually have no issues cutting graphics but when it comes to cutting the raiders logo it pulls off vinyl while cutting. I changed blade offsets, changed blades, changed angle blades, changed vinyl both thicker and thinner and nothing seems to work. This is for a small project like a 4x4 picture. This would not be an issue for a decal but I am using for etching and so it eats the things I need to keep. Sorry and the cutter is an sc model
usually lifting vinyl is caused by too much blade.  Also clean that blade now.  with alcohol, to get all the adhesive off of it.
Probably your design has fine / small details -- go into your design and check the nodes.
