limitedlane 0 Posted May 3, 2013 Just set up my graphtec CE5000 and the cut size is wrong. I have an file I am trying to cut and it is 8x16 when it is sent to cut it is cutting only the bottom part of the design and has enlarged the text to huge. What is wrong and help waisting soooo much vinyl Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 3, 2013 Not the first person i have heard of having trouble with scalp and a graphtec - seems it is not optimized for the better cutter. kinda like running your porshe on kerosene. hopefully a scalp user will have the answer Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 3, 2013 download cutmaster from graphtec and cut directly from that - see if that helps http://www.graphtecamerica.com/support/ it is very much like the production manager from flexi Share this post Link to post Share on other sites
lueman 19 Posted May 3, 2013 I don't know much about these machines but sounds like a language issue, rather than communication. Set language to Graphtec/Craft robo, GPGL. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 3, 2013 lueman, I can tell you from experience if the language is set wrong for the software it won't cut at all - not cut incorrectly. Share this post Link to post Share on other sites
signwave 0 Posted May 10, 2013 If it is cutting, language is most likely correct. On Graphtec machines there is also a Step Size (508,1016,2032,etc..) setting so make sure whatever is set on the Graphtec matches the setting in SCALPro Share this post Link to post Share on other sites
