HEBERT2007 1 Posted May 2, 2013 Please someone help me!!!! I'm sure there is some quick fix but I can't figure it out! No matter what I try to cut text or picture it is cutting super tiny! Example: text shows on screen 12x6 and shows in print screen 12x6 but cuts on cutter like 1x1 Please please tell me how to fix before I go insane! 1 Share this post Link to post Share on other sites
09sporty 6 Posted May 2, 2013 What kind of cutter you using? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 2, 2013 what software are you using? What ever it is,, there should be a feature for calibrating your cutter. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 2, 2013 in the bottom of your cut window in signblazer is the sizing got numbers in it ? did this get changes somewhere or still read 0? Share this post Link to post Share on other sites
HEBERT2007 1 Posted May 2, 2013 I'm using signblazer. Everything was working fine then my husband tried to see if could learn to use the program and vinyl cutter all in one night, next thing I know everything is screwed up! Share this post Link to post Share on other sites
HEBERT2007 1 Posted May 2, 2013 I'm not sure what you are exactly talking about "cut window" but everything that shows somewhere to have numbers has numbers. Even when I click to cut is reads the cut tile section as what it should be but still cuts very small. Share this post Link to post Share on other sites
mb20music 760 Posted May 2, 2013 At the top left of the screen, is it set to Millimeters instead of Inches by any chance? 2 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 2, 2013 I'm not sure what you are exactly talking about "cut window" but everything that shows somewhere to have numbers has numbers. Even when I click to cut is reads the cut tile section as what it should be but still cuts very small. when you are in the cut screen getting ready to cut look at the bottom middle of the sceen for the proportions area - if this has numbers in it SB is resizing it on you Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 2, 2013 here... http://support.uscutter.com/index.php?/Knowledgebase/Article/View/23/5/my-cut-size-does-not-match-the-indicated-size-in-signblazer 1 Share this post Link to post Share on other sites
HEBERT2007 1 Posted May 2, 2013 here... http://support.uscutter.com/index.php?/Knowledgebase/Article/View/23/5/my-cut-size-does-not-match-the-indicated-size-in-signblazer YOU ARE A LIFESAVER!!!! THANK YOU SO SO MUCH! I literally have been sitting at my computer crying for the past few hours! FIXED! I owe you!!!!! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 2, 2013 YOU ARE A LIFESAVER!!!! THANK YOU SO SO MUCH! I literally have been sitting at my computer crying for the past few hours! FIXED! I owe you!!!!! Glad you got it, You don't owe me a thing. Pay it forward. Help some one in the future.... 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 2, 2013 And who says that size doesn't matter? !!!!!! 1 Share this post Link to post Share on other sites
