Ricktharula 0 Posted April 27, 2013 Ok I'm sending my vector designs using illustrator cs6 to cut master 3 for the cutter. But when I start the job the cutter cuts through the vinyl cause it traces over & over tell it cuts threw. But if I open up graphtec studio & type a font & send the job it cuts perfect. What am I doing wrong? I'm frustrated & I'm losing clients & vinyl. Does anybody have a link if I'm making the vector wrong use illustrator wrong? I take all comments please. If u have any links to use illustrator correctly cause I'm also just learning. Thanks Share this post Link to post Share on other sites
bikemike 711 Posted April 27, 2013 Follow this thread. Looks to be the same problem. http://forum.uscutter.com/index.php?/topic/38065-duplicate-paths-in-illustrator-image/ Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 27, 2013 if it is ever able to cut all the way thru you have too much blade out also - this won't fix the multiple cuts (I think Mike has you on the track for that problem). but you should not be ABLE to cut all the way thru. Share this post Link to post Share on other sites
