denise025
Can't figure out how to work my timer
I ordered the basic 15" X 15" Clamshell heat press this week and can't figure out how to set the timer.  It won't come on until I shut the press all the way, and that is when it should start counting, not just come on?:huh:?  It is the red one that I have attached a picture of.
post-16874-0-62142900-1365900367_thumb.j
You have to look at your manual.   I don't have one like that but once it reaches temperature then you close it and the timer should start.  On mine I set the timer at what I want then I have to get out of that screen to continue on it might be like that?
You close the lid, the timer display lights up and set the time using the up button. Let go of the up button
when you reach the desired time. The timer display should blink about 3 times and then the timer should be set.
You won't have to set the timer each time you use the press, it will keep the programmed time in memory.
