bigdaddy1975 1 Posted April 11, 2013 hey guys i just downloaded inkscape. how do i install my cutter to cut from inkscape. thank you Share this post Link to post Share on other sites
joker 618 Posted April 11, 2013 You dont cut from inkscape. Inkscape is a design program that is free. You will need to download and install Signblazer or something else Share this post Link to post Share on other sites
bigdaddy1975 1 Posted April 12, 2013 <blockquote class='ipsBlockquote'data-author="joker" data-cid="306868" data-time="1365717282"><p> You dont cut from inkscape. Inkscape is a design program that is free. You will need to download and install Signblazer or something else</p></blockquote> Share this post Link to post Share on other sites
bigdaddy1975 1 Posted April 12, 2013 Is signblaze free to down load Share this post Link to post Share on other sites
joker 618 Posted April 12, 2013 yes it is in the forums. scroll down and look for it in the signblazer section. You will need the one that says all cutters Share this post Link to post Share on other sites
steve0xr 2 Posted April 12, 2013 i just save my inkscape vector as an eps and open it with my cutter software Share this post Link to post Share on other sites
bigdaddy1975 1 Posted April 12, 2013 Ok thank u guys Share this post Link to post Share on other sites
Coaster36 327 Posted April 12, 2013 I think I read that you can cut with inkscape if your using a linux operating system. If you go the signblazer route, which is the way I do my cuts. I highly recommend saving everyhing as an .eps(to cut) AND as an .svg(to edit). Inkscape for some reason wont import .eps files. It does in linux. So what will happen is youll try to cut something and then youll find something wrong with your file and you wont be able to import the file back into inkscape to fix the mistakes. I learned that the hard way. Share this post Link to post Share on other sites
steve0xr 2 Posted April 14, 2013 I highly recommend saving everyhing as an .eps(to cut) AND as an .svg(to edit). Inkscape for some reason wont import .eps files. +1 Its also a good idea to download an eps file viewer, so when your looking for an image you dont have to open every single one in your cutting program to find what your looking for. Share this post Link to post Share on other sites
Coaster36 327 Posted April 14, 2013 Good idea. I use irfanview Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 15, 2013 There is a free open source plugin for Inkscape called Ghostscript that will enable inkscape to open and edit EPS files. Share this post Link to post Share on other sites
Coaster36 327 Posted April 15, 2013 Ive tried it. Its not as easy as it seems. You cant just down load ghostscript and boom inkscape opens eps files. I tried and tried to get it to work. I followed all the links and it still doesnt work. I dont know why they cant just write the code into inkscape. Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 15, 2013 What sort of problem are you running into. You should just be able to download and install Ghostscript and then a quick edit of the system environment variables. Here are the instructions that I used. http://ask.brothersoft.com/how-to-open-eps-files-in-inkscape-142659.html Share this post Link to post Share on other sites
steve0xr 2 Posted April 18, 2013 im gonna have to try it , thanks for the info Share this post Link to post Share on other sites
Robert H. Bigart 64 Posted April 18, 2013 I have cut from "Inkscape" but was not satisfied. Bob Share this post Link to post Share on other sites
