LLaurence
My MH 871-MK2 is thinking?
So when I first bought this cutter it was great and ran through thoroughly no problems. Until about a week ago. Every time I send things to my cutter now it just pauses randomly like it is thinking what to do next. I would say it does it every 15-30 seconds during the cut. Is this normal? A glitch maybe? A warning sign on a malfunction? Any one else experience this problem? Have a solution?
unplug it for a few minutes so it will clear the memory and try it.I had one do this once and I had to do that every day or two.
I just tried ..... its still doing it. . :( is there any other way to clear the memory
If you want to eliminate the possibility of the cutter being at fault, download & install SignBlazerElements and use that to cut, and see if the machine still hangs. If not, then you have a SCALPRO issue.
http://www.mystat.com/Signblazer.zip
(install v6 first, then the UK version, and apply the Patch to eliminate the nagging start-up screens)
