Luvmydane 1 Posted April 4, 2013 I have a Creation PCUT that I have had for 3 years and use often. Last night in I cut several items and then went to cut another and I got the message "Can not open the output device. Error intializing cutter" when I have got this in the past I turned off my computer and restarted and everything was okay, this time I cannot get it to work. Any ideas or help would be appreciated, Thanks so much! Share this post Link to post Share on other sites
slice&dice 2,211 Posted April 5, 2013 Unplug and plug back in the USB cable. Share this post Link to post Share on other sites
Luvmydane 1 Posted April 6, 2013 I have plugged and unplugged several times, already, no luck. I wonder if there are any settings I am not aware of that may have got changed. This is the first time I have had this problem that won't correct. Share this post Link to post Share on other sites
xpaperman 719 Posted April 6, 2013 double check that your port setting is set to the right port (the one your cutter is connected to) if that is good, might try swapping your cable out, just a thought Share this post Link to post Share on other sites
Luvmydane 1 Posted April 8, 2013 How do I check my port settings? Could this happen, even though I was cutting and then just changed vinyl and then when I cut the next one it started giving me the message? Thank you for your help. Share this post Link to post Share on other sites
