alikat1109 0 Posted March 28, 2013 Hello, I just put together my MH871, and I ran a test cut and (several times), and it's cutting through my image. How do I stop this? Thanks Allison Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 28, 2013 If you have not activated your software, you need to do that.. 1 Share this post Link to post Share on other sites
alikat1109 0 Posted March 28, 2013 I did but shut down after. I will try again tomorrow. Thank u Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 28, 2013 Your welcome also there are many updates to the software since distribution. Follow thru with the updates. Share this post Link to post Share on other sites
nava2642 0 Posted August 30, 2013 Hello, think this might help. I had the same exact problem, I think? Was putting in designs or fonts or whatever and the cutter would just make random cuts thru my vinyl or whatever I was cutting??? I called US Cutter support and, think his name was Kyle, helped me out. He said I didn't even have a driver installed onto my computer to run the program correctly?? If you call them they can log on, on their side, to get into your computer and fix this problem, anyway, it made a huge, huge difference. So far all cuts after that installation are flawless. Very happy with my SCAL and SC series cutter now. Hope this helps, Good Luck!! Share this post Link to post Share on other sites
Bruisbe 19 Posted September 6, 2013 Also...if you can use a serial connection instead of usb..Do so... Another must is if you are using a stand...make sure you ground the cutter to the stand using the supplied cable...after doing these two things i never ran into those line issues any longer 1 Share this post Link to post Share on other sites
Bruisbe 19 Posted September 6, 2013 Wowowowow...i just realized the thread necro that just happened Share this post Link to post Share on other sites
Rodger 527 Posted September 6, 2013 " thread necro " ?? explain please 1 Share this post Link to post Share on other sites
Bruisbe 19 Posted September 6, 2013 " thread necro " ?? explain please The last post in this thread was from March 2013...The thread Died....Nava posted on it in Aug...sorta bringing it back to life... Term Thread Necro is used in forums sometimes when stuff like that happens. 2 Share this post Link to post Share on other sites
Rodger 527 Posted September 6, 2013 Ahhh , I understand now . I knew what necro meant , but when you said " just happened " I didn't understand . It seems more like a ressurection . There has been many threads that had been dead for years and when a new influx of members join .. some reread much of the forum and comment on old threads . It is all good . Heck some subjects are so good .. they will be good to talk about decades later .. Just ask John ... He has declared several threads " The Thread that Won't Die " Share this post Link to post Share on other sites
jaybyrd 3,770 Posted September 6, 2013 Around here bringing back from the dead is usually 1-4 years old. And it happens all the time which is cool because some of the stuff they dig up hasn't been read by the newer members. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted September 6, 2013 Oh and my personal fave is zombie thread. Risen from the dead. 1 Share this post Link to post Share on other sites
