sink 1 Posted March 21, 2013 I'm looking to purchase a new cutter today as I'm more than frustrated with the copam cp2500 and ready to move up and save myself some time and headache. That being said I want to make sure I don't purchase the 6000 and wish I had went with the 8000 later on so I'm wondering if anyone can give me any insight on if I really need the 8000. What we're doing at the moment is just vinyl decals for car windows. We would love to contour cut around printed vinyl but we cannot afford to print vinyl right now (unless I'm missing something on a cheaper way to do it than buying a $10k machine to print). I want to be able to cut small letters and right now if we get anything too small the copam will either rip them right up or make horrible cuts around them. Any help is appreciated. Thank you! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2013 If your just going to stay with a 24" Machine the Ce6000-60 will do all you need. The Graphtecs are great with small lettering and detailed designs. For small detail jobs it is recommended to use a 60 degree blade 1 Share this post Link to post Share on other sites
Rodger 527 Posted March 21, 2013 How small are you cutting ? I have had 2 Copams for almost 6 years & have cut 1/8" letters . Cole casual lower case " e " is very difficult to weed at that size though . I hardly ever make anything that small & that was a decal for myself . I use 170 grams of pressure , a regular 45 degree blade that is only sticking out the thickness of the vinyl . Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2013 are you sure you have made all of the correct adjustments to your blade depth, blade offset, speed and force? Share this post Link to post Share on other sites
sink 1 Posted March 21, 2013 I've messed with the copam so much I'm just frustrated with it. The letters that I cut this morning were 1 cm which I increased the size to 1cm because it was tearing the original size so bad. I've changed the force, offset, speed..... Went to a 60 degree even. The corners seem a little jaggedy. It's only on some letters though! Some cut just fine (weeding is a B but anyhow) then other letters it just looks bad. I went to oracal 651 thinking that may help. It's better but not the best. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2013 what vinyl was you using that was so bad? If the vinyl is tearing, and not cutting, sounds like other problems. Share this post Link to post Share on other sites
sink 1 Posted March 21, 2013 I was using greenstar. I'm not saying it was so bad but I was trying to find the problem and that was not solving my issues. Share this post Link to post Share on other sites
mb20music 760 Posted March 21, 2013 I use 170 grams of pressure That seems like overkill to me? On my Copam I use 20 grams for regular vinyl, 60 grams for transparent, and 120 for reflective. Share this post Link to post Share on other sites
sink 1 Posted March 21, 2013 I have tried 60-170 grams on my tests. The test circles are fine but when I actually run the job - ahhhhh Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2013 also slow down your machine Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2013 I would suggest, making sure your blade is set correctly first. Have you done this correcty now with the Oracal 651 vinyl you are using? To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. Run the test cut feature of your machine, to make sure the vinyl is cutting correctly. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 21, 2013 I think skeeter is on the right track - usually the ripping up is too much blade - a copam should have no problems down to about 1/4" Share this post Link to post Share on other sites
