slice&dice 2,450 Posted March 20, 2013 OK, here's what I found, on USCUTTER's sales site. http://www.uscutter.com/Catch-Basket-for-LaserPoint-II-Vinyl-Cutters It's a media catch basket unit, that is designed to go into the LPII stand (25", 31" or 50") The thing is, this actually appears easy enough to adapt onto the stand of almost ANY cutting machine. Pricing? Between $30-$40 depending on the size. That's correct, forty bucks. I ordered one, and I'll be getting it tomorrow, and will post photos (or a video) of the results as I adapt it to fit my MH cutter. Stay tuned, catch-basket fans. Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted March 20, 2013 Not a bad price. I made mine for less then 20 bucks. Still a great find. Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 22, 2013 Unpacked the box this morning, and discovered that the distance between the rods will not permit installation on my MH stand. However, it is perfectly measured for the width of the SC stand, all I need to do is drill the appropriate holes and insert the rods. I did not have the correct drill bit on hand today, so tomorrow that's what I'm going to attempt. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 23, 2013 Unpacked the box this morning, and discovered that the distance between the rods will not permit installation on my MH stand. However, it is perfectly measured for the width of the SC stand, all I need to do is drill the appropriate holes and insert the rods. I did not have the correct drill bit on hand today, so tomorrow that's what I'm going to attempt. Duct tape! WD-40 isn't appropriate for this applicaiton so it must be duct tape . . . . and of course a hammer! 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 23, 2013 I was really tempted to go with the duct tape, let me admit that right up front. It turns out that the legs of the SC stand have INTERNAL baffles (supporting metal), and when I started drilling through, I had to go into those and keep the holes straight. In fact, I had to drill from each side, and make sure I met exactly in the middle on a perfectly straight line (since the drill bit is not long enough to go all the way from front to back of the stand leg in one shot). Somehow, I managed to do that, and had holes that lined up. In case anyone else is looking to make the same purchase, the width distance for these brackets is 37" across. Now, my SC unit is all ready to go with a blue catch-basket. Here's a series of pix taken step-by-step while doing the installation/assembly. Share this post Link to post Share on other sites
xpaperman 719 Posted March 24, 2013 Hey Slice, how for out do these stick from the machine. As in how far away from the wall will my machine have to be and how far out does the front one stick. Do they just slide out when not in use? Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 24, 2013 Needless to say, I'm very satisfied with the result. Yes, xpaperman, the rods slide for adjustments in and out. The rear one I'm keeping set maybe 4" further than those brackets for the vinyl rollers, allowing for play when pre-unrolling. The front pair is out approx. 10" (it shows as being extended a lot more in the photos, but I've since pushed them in when I started operating) Oh, I forgot to note the diameter of the drill bit, I'll look at that tomorrow and post back. Share this post Link to post Share on other sites
xpaperman 719 Posted March 24, 2013 Thanks for the info on this.... I find it very helpful Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 26, 2013 It's the 3/8" bit for the holes. Glad to have been of some help. Share this post Link to post Share on other sites
