rex 7 Posted March 10, 2013 i traced a skull in illy., from a scanned magazine, to make an airbrush stencil, but when it goes to my mh871 from signblaser to cut, it starts cutting on the node path, then just goes off in another direction, to and fro, not on a path,,,,what have i done wrong with this thing, can anyone figure this out for me? thanks for any input skull.eps Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 10, 2013 There is no inside/outside to the path. They are just lines. You can't just cut a line.. You have lines not even connected, and crossing other lines. It will not work. Your file needs a lot of work.. Zoom it up big and look at it...in wire frame. Share this post Link to post Share on other sites
mb20music 760 Posted March 10, 2013 Try this skull.eps skull.SBD Share this post Link to post Share on other sites
rex 7 Posted March 10, 2013 There is no inside/outside to the path. could you explain this,,,,i used the pen tool to draw it,,,,making nodes,,hence vector?? Share this post Link to post Share on other sites
rex 7 Posted March 10, 2013 mb20music, thanks, that worked, except for the lower jaw didnt come through,so,,what did you do that i wasnt doing,,,,ive made a few stencils before without any problems,,now im stuck on this one Share this post Link to post Share on other sites
mb20music 760 Posted March 10, 2013 After I imported your .eps file I welded it and then thickened the lines with the manipulate+expand+outline function. I did a little node editing and it l noticed the middle bottom tooth was missing so I added a new one (maybe it was supposed to be missing?) but I added it in, thought it would look better. I don't know what happened with the lower jaw, can you post a .jpg image of what the skull is actually supposed to look like? Share this post Link to post Share on other sites
rex 7 Posted March 10, 2013 heres the jpeg., its scott mckays skull in this months airbrush action magazine,,,i was doing this as a personal project, so its not exact as the pic, but youll get the idea Share this post Link to post Share on other sites
mb20music 760 Posted March 10, 2013 heres the jpeg., its scott mckays skull in this months airbrush action magazine,,,i was doing this as a personal project, so its not exact as the pic, but youll get the idea I see...actually I was wanting to see how your vector turned out in regards to the lower jaw area. Share this post Link to post Share on other sites
rex 7 Posted March 10, 2013 gonna give another go tomorrow,,fed up with it for the night,,,new day,new eyes,,hopfully,haha,,,sucks i wanted to start this tonight,,,i could sketch it and cut it, but then thats why i got a plotter,,,,,,,thanks for the help by the way, i appreciate it Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 10, 2013 There is no inside/outside to the path. could you explain this,,,,i used the pen tool to draw it,,,,making nodes,,hence vector?? LIke, he said below: he did.. because there is no thickness to the line. inside/outside. thickened the lines with the manipulate+expand+outline function Share this post Link to post Share on other sites
rex 7 Posted March 11, 2013 well something else is going on, i just tried cutting some files that i have cut before, and its doing the same thing,,,,for instance; it will start a cut,say, the left eye socket on a skull,then go to the jaw bone, but the knife stays down makiong a cut from eye to jaw, so i end up with thefile useless with zig zag cuts throught,,,,when its cutting you can see it it signblaser preview pane, just going nuts if i do it in outline like suggested it does work better, if i was making decals i could do that, but stencils is different,,, ive used the mh871 along with signblaser and adobie to make stencils for 3 years without any problems untill now??? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 11, 2013 does the blade stay down all the time? If so, sounds like you fried the zchip... Share this post Link to post Share on other sites
rex 7 Posted March 11, 2013 thats whats strange,it does go up and down, sometimes and stays down sometimes,,,,is the chip replacable? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 11, 2013 yes, http://www.uscutter.com/Z-Axis-Carriage-Chip-for-MH-Series-Cutter but also make sure you have your cutter grounded to the stand if you have one. Share this post Link to post Share on other sites
mr300s 1,272 Posted March 11, 2013 It could also be a issue with Sign Blazer delete it and re install it you wont lose any files... Share this post Link to post Share on other sites
rex 7 Posted March 11, 2013 using the pen tool and paper so i can show you whats going on,heres whats happening, the black is where it cut correct, the red is where it made cuts on its own, so to speak,, ive used thi file many times and its never been a problem Share this post Link to post Share on other sites
mr300s 1,272 Posted March 11, 2013 I think that why the easiest to start with is a re install Share this post Link to post Share on other sites
rex 7 Posted March 11, 2013 your probably right,thats easy enough to do,dont think its the chip since its not down all the time, but its only 5 bucks so if the reinstall doest do it, i`ll order one and try that thanks to everyone on the advice, i appreciate your guys and gals help Share this post Link to post Share on other sites
rex 7 Posted March 11, 2013 ok, i got it to make a cut right, i did the reinstall, no change at all,,,,so i did a new trace(for about the 5th time),,this time i set my pen at 1, usually i use 3, then when i finished i set it to outline path,and it cut fine,,the outline is so close its unnoticeable,,,,i am stumped,,i dont know what happened to cause my problem,or if i even really fixed it,,,tomorrow i will try cutting some tried and true stencils, and if they cut they way should, all will be good,,if not,,,well i got a big bottle of single malt that i am gonna have a long talk with,,hahah,,,thanks for the help guys Share this post Link to post Share on other sites
mr300s 1,272 Posted March 11, 2013 The reinstall seems to work most of the time with issues like that. I think the program just gets corrupt somehow with no support. At least its working... Share this post Link to post Share on other sites
