ThermoPuke
SignzWorld Creation Plugin Issues
Trying to use Creation's Illustrator plugin but it is not even using the offset or overcut value.  This plugin works great with exception to that.  Could someone from US Cutter contact Creation to get them to fix it.  Seems like a simple fix even though the software is beta.  I'm using a PCut CTN630
Trying to find a free alternative to SignBlazer which handles illustrator eps very poorly.  Sign Cut works great but is $360 and this free plugin works as good but the offset does not work :\  You'd think the manufacturer's software would be spot on but its another cheap thing from China, sigh...
If only the pcut had a manual offset setting...
http://www.pcut-cn.com/en/support/?type=57
