noreaster3 0 Posted February 23, 2013 I have a MH721 cutter and using 631 vinyl. What should I set my speed and force at on the cutter. Thanks Jim Share this post Link to post Share on other sites
SurberSigns 24 Posted February 23, 2013 I have a MH871 i set my speed around 210-220 and cut pressure around 30-40. Share this post Link to post Share on other sites
xpaperman 719 Posted February 23, 2013 I have a SC series cutter. I run mine slow. I run the speed at 100 and my pressure at 30g. I seem to do lots of small things so it makes me feel better running the slow speed. Not sure if it matters but I feel better :-) Share this post Link to post Share on other sites
constricted 27 Posted February 24, 2013 you guys don't have difficulty weeding at those pressure settings? i have a tc series and i usually run my speed anywhere from 100-500 and pressure from 70-100g... it seems if i use any less pressure weeding becomes a bit more difficult (i use oracal 651) Share this post Link to post Share on other sites
xpaperman 719 Posted February 24, 2013 I don't have any issue weeding at 30 no. Originally I had the pressure higher and just started lowering it to see how low I could go. I had it at 25 but on occasion I would hit a spot here and there that was a tad tricky so I upped it to 30 and no issues for me. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted February 24, 2013 Do all of these machine read the same scale for speed and pressure. On my Laserpoint 1 I run pressure at 95 and speed between 50 and 60. Any higher speed and cut accuracy suffers on my machine. Jay Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 24, 2013 I find every cutter is a little different so my answer would be just enough pressure to get it done and slow enough to get a clean cut. even the same model cuters have been known to have differences in settings, especially the value cutters as tolerances aren't real tight on those when made Share this post Link to post Share on other sites
ladysewnsew 2 Posted March 2, 2013 I have the MH721 and I am also new but my settings seem to be working for me.. Speed is 50 and pressure is 100 -110 for GT5 Vinyl.. HTH Share this post Link to post Share on other sites
ladysewnsew 2 Posted March 7, 2013 Hey Guys, Thank you for all the great advice... I have it up and running great now.. Just took some time of playing around with it to get it right Just a small learning curve but got the hang of it now.. Thank you all again I appreciate your suggestions.. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted March 8, 2013 Like Dakota said all cutters are a little different go by your cutters manual as a starting point then adjust speed for cut quality . Your pressure can be adjusted from your test cuts and test cuts should be made every time you change vinyl . Dan Share this post Link to post Share on other sites
egobuster1 9 Posted March 13, 2013 my cut pressure is between 100-120 for oracal 651 vinyl and my speed really just depends on what im cutting. if im cutting something larger then i might run it at 100 or higher but i just did a bunch of very small text decals and cut them all at 20. Share this post Link to post Share on other sites
Bridgewater Embrdoiery 0 Posted February 19, 2018 I have an SC. I set my speed to 700 and cut at 60g. I haven't had any issues using a 45 degree knife. Share this post Link to post Share on other sites
eprcvinyls 62 Posted February 19, 2018 4 hours ago, Bridgewater Embrdoiery said: I have an SC. I set my speed to 700 and cut at 60g. I haven't had any issues using a 45 degree knife. WOW you run it that fast w/o issues.. Ive got my SC2 at 100 speed and about 92 force. im new but seems okay. im wondering for me if there any settings inside the VM i should change. Share this post Link to post Share on other sites
haumana 1,220 Posted February 19, 2018 3 hours ago, eprcvinyls said: WOW you run it that fast w/o issues.. Ive got my SC2 at 100 speed and about 92 force. im new but seems okay. im wondering for me if there any settings inside the VM i should change. I have an original LP and buzz at 60, 40 for the smaller stuff. What kind of settings do you think you need to change in VM? Share this post Link to post Share on other sites
eprcvinyls 62 Posted February 19, 2018 12 hours ago, haumana said: I have an original LP and buzz at 60, 40 for the smaller stuff. What kind of settings do you think you need to change in VM? Im not sure, just the boxes you can check and the numbers the Blade offset default its on 0.20 and the overcut is 2.00 blade type:drag knife 45degree advanced after plot.... i really not sure what any of that is im using the red blade that came with the machine. Share this post Link to post Share on other sites
darcshadow 1,626 Posted February 19, 2018 The blade offset is to account for the fact that the point of the blade is not actually in the center of the holder. To test if an adjustment is needed cut a a simple square, look closely at the corners and compare them to the image below. Overcut is how far past the start top point the blade will travel when completing a cut. The value cutters will not always complete a cut, the overcut setting compensates for this by traveling the specified distance extra to ensure that the start and stop points meet or overlap. Advance after plot is a nice option, it simply advances the vinyl out so that you can easily cut it off. Not sure about the SC, but I know the MH when it does this, the origin does not change. So unless you reset the origin the cutter will back up the vinyl, and since you've cut it off, the vinyl will fall out of the machine and the blade will cut into the cutting strip. 1 Share this post Link to post Share on other sites
eprcvinyls 62 Posted February 19, 2018 4 hours ago, darcshadow said: The blade offset is to account for the fact that the point of the blade is not actually in the center of the holder. To test if an adjustment is needed cut a a simple square, look closely at the corners and compare them to the image below. Overcut is how far past the start top point the blade will travel when completing a cut. The value cutters will not always complete a cut, the overcut setting compensates for this by traveling the specified distance extra to ensure that the start and stop points meet or overlap. Advance after plot is a nice option, it simply advances the vinyl out so that you can easily cut it off. Not sure about the SC, but I know the MH when it does this, the origin does not change. So unless you reset the origin the cutter will back up the vinyl, and since you've cut it off, the vinyl will fall out of the machine and the blade will cut into the cutting strip. Thank you for the examples Share this post Link to post Share on other sites
