timcos 3 Posted February 11, 2013 When I make the custom size of the project to the max dimensions...it is 72 inches. I have a product that has very long swooshes for a yogurt truck. 194 inches long to be exact is the whole project. I imported the SVG into SCLAP3 and of course it hangs off the edge of the project by 122 inches. That does not bother me as much as when I go to cut... it only shows 72 inches of my project. Will it cut the whole thing...or only 72 inches? Thanks Tim Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2013 Have you activated the software, and done all the updates that are available? It should be larger Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 11, 2013 If you have the Pro version the cutting mat size is up to 200" x 200" but SCAL3 and SCALP are two different programs I believe. 1 Share this post Link to post Share on other sites
Rodger 527 Posted February 11, 2013 Absolutely 2 different versions . Pro has the bigger work space allowance , additional weeding options etc . Until you activate the pro , it won't let you use the added features . Share this post Link to post Share on other sites
