xpaperman 719 Posted April 14, 2016 Also on glitter..... you need lots of pressure too! 1 Share this post Link to post Share on other sites
whobbies 0 Posted September 30, 2019 OK, First I own a manufacturing company, and consider us to be a teaching company. Our adverting department made vinyl products (adverts / signs) for over 35 years, and we had only Roland equipment. I recently had to purchase a cutting machine for small in house application and did not want to spend the money as I had done in my former business. Let's face it, these machines are built pretty well for the money, but they are not going to produce the ease of use such as $2500 Roland is know for. I too got a bit frustrated with the blade-cutting issues, too shallow, too deep, and battle because I was used to a machine that performed this action by itself. Here's the deal. There is a fine point from right to wrong when making the blade adjustments. It is true that the blade needs to protrude very little, and though I did this or thought I did between adjustments I found that I was making too aggressive adjustments thinking what's one or two turns on the blade carrier. Well, I found that is to much. Adjust the blade so it is about the depth of a standard business card (.020 "). I set the machine at 60 grams and worked down each test, and in my case ( using this companies vinyl material ) I good good results at 20 grams. Of course other manufacturers materials whether cast or calendar grade will require lesser or more pressure. In our case we are using the "outdoor calendar" material. I would also recommend using the best cutting blades, ( I like 45 degree ). I am however using their cheaper one's which could be why I had such a "fine tuning" experience? Don't get frustrated they do work well, especially for the money, just make very minimal adjustments on the blade holder, and be sure you do place it back in a bottom out on the cutter head. While I'm at it a little trick for weeding. Always start at the top right corner and weed to the left or lower left. It's best to have someone walk the paper downward and you pull the vinyl away and off at a upper angle. Good luck, I hope this helps. Tony C. Warehouse Hobbies Inc. DBA: Rock'in Radios P.S.- I am quite pleased with this machine (US Cutter MH721) so far? Share this post Link to post Share on other sites
darcshadow 1,625 Posted October 1, 2019 The thickness of a buisnes card .020" is about 10 times too much blade. Oracal 651, for example, is only 0.0025" thick. So you only need that much blade sticking out to cut through it. Any more than that and you are cutting into your backing material. Mz Skeeter has posted hundreds, if not thousands of times the correct way to set your blade depth. Follow her guide and you'll be cutting great right away. 2 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 1, 2019 This is the correct way to set your blade depth. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel the blade tip out of the blade holder. You should only be cutting with the very tip of the blade. Most vinyl is only 2-3 mil thick. so it only takes the very tip of the blade to cut. 2 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 1, 2019 Not so sure tony read the first post in this thread . . . . thanks for skeeters instructions that have literally helped thousands of people reading it on this forum. 2 Share this post Link to post Share on other sites
Racer88 24 Posted October 6, 2019 On 10/1/2019 at 9:48 AM, MZ SKEETER said: This is the correct way to set your blade depth. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel the blade tip out of the blade holder. You should only be cutting with the very tip of the blade. Most vinyl is only 2-3 mil thick. so it only takes the very tip of the blade to cut. I agree with Mz. Skeeter. I have been setting my blades this way for years and with Clean-Cut blades, I get excellent results for a basic MK 871 cutter. It just takes time and testing to dial it in for each type of vinyl. 1 Share this post Link to post Share on other sites
