teamnrgllc 0 Posted January 23, 2013 I'm using a MacBook Pro and the Laserpoint 2 Cutter. The cutter and my computer communicate just fine, where i'm having an issue is when the cutter is cutting the blade doesn't lift up off of the vinyl. For example; when I'm cutting a word it cuts the letters out and cuts from letter to letter as well. Anyone have a solution that can help? Thanks. Share this post Link to post Share on other sites
23ccc 0 Posted January 30, 2013 Having the same problem, any solutions? Share this post Link to post Share on other sites
slice&dice 2,250 Posted January 31, 2013 You'll need to troubleshoot with USCUTTER support, it could be anything from a Z-chip failure to an improperly seated blade holder. Share this post Link to post Share on other sites
Rodger 527 Posted January 31, 2013 or not activating SCALPro . Share this post Link to post Share on other sites
jenner9119 0 Posted February 17, 2013 I am too having this problem did you guys ever find a solution?? Share this post Link to post Share on other sites
djque 246 Posted July 25, 2013 I was having that issue to. I adjusted the blade and it fixed it. Share this post Link to post Share on other sites
geekinesis 0 Posted January 2, 2014 if you over tighten your blade holder it can sometimes catch on the plastic housing and cause it to stop moving upwards. Share this post Link to post Share on other sites
bouteeques 0 Posted February 25, 2014 I am using a MAC desktop and have noticed when I am cutting a huge list of names, it does the same thing you are experiencing. In addition to that, very recently, when cutting a project, the machine will cut, but when it finishes the project, it just stops, blade down, and does not return to home/original position as I have it set to do in the settings. I have tried switching to another setting (advance an inch after cutting) to see if the cutter will recognize the setting , but it still just stops in place when it's done with a project. I have to shut the machine off and turn it back on in order for the blade to lift and return to home position. Any idea why it's doing this? Any help would be appreciated. Thanks Share this post Link to post Share on other sites
