darksky911 0 Posted January 20, 2013 I got the cutter for 3 days now and had waste a lot of vinyl already. The cutter always gives me bonus cut my project. Here is what im already done: used serial port, ground the cutter, update driver and same things happen. Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 21, 2013 What cutting program are you using? Share this post Link to post Share on other sites
darksky911 0 Posted January 21, 2013 What cutting program are you using? SCAL 3 which came with the cutter. I already uninstall and re install it. but no help. Share this post Link to post Share on other sites
bikemike 711 Posted January 21, 2013 There is something about registering it. If you don't it will cut through. not sure if that is it or not. It could be it is still in demo mode. Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 21, 2013 I believe it needs to be Activated (registration is something else). Share this post Link to post Share on other sites
bikemike 711 Posted January 21, 2013 I guessed. I only tried the demo to see how it looked. But ya..... ^^^^what he said^^^^^^ Share this post Link to post Share on other sites
darksky911 0 Posted January 21, 2013 talk to the support today for 3 hours finally it works now. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 21, 2013 talk to the support today for 3 hours finally it works now. It could be helpful to someone else, who has this problem, if you would share the solution to your problem, If you know what is was. Share this post Link to post Share on other sites
darksky911 0 Posted January 22, 2013 They changed some setting on the device manage on my computer. Share this post Link to post Share on other sites
