adil 1 Posted December 26, 2012 I've Icutter machine made in china the problem is the machine sudden stop and it always keeps slice the paper and all my works destoryed it doesnt finish the cut the drawing is their any problem in setting ? if any help please reply 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 26, 2012 Sorry, you don't give enough info to help you, If the cutter is connected by USB then connect it with a serial cable or keyspan adapter. Use some static guard in the area, put dryer sheets in the vinyl, or wipe your vinyl with dryer sheets. Static can cause these problems. With your lack of info here, as to the cutter brand , type of connection, type of cutting software and operating system, this the only info I can give you for help. If that doesn't help, contact the tech support where you bought your vinyl cutter. Share this post Link to post Share on other sites
adil 1 Posted December 28, 2012 Thanks my dear I'll send for you all details with pictures Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 28, 2012 Skeeter give some good advice on the static - it is a common problem this time of year with the cheaper cutters Share this post Link to post Share on other sites
