prettybird 0 Posted December 13, 2012 Hello, I am using Flexi sign pro 8.1 and I have some open type fonts that suddenly quit working yesterday. (two of them are bickham script and filmotype honey) It seems like all my open type fonts quit working, but my true-type fonts still work. I opened my paint program to see if the font works in there, and it does work in there, just not on flexi and they were working fine before yesterday. Any ideas on what I can try to fix this? I tried re-downloading the filmotype one from where I purchased it from (myfonts.com) but it still doesn't work. Any help would really be appreciated. Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 13, 2012 have you tried system restore,on your computer, back to an earlier time when they worked? Or reinstall Flexi. Share this post Link to post Share on other sites
Scottyy 3 Posted December 13, 2012 I have the same problem. I am using flexi starter 8.5 for windows. I am trying to reinstal now. When you select the font everything is normal then when you type nothing shows up? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 13, 2012 I have had my Flexistarter software installed for years. I have never had that problem... Share this post Link to post Share on other sites
Scottyy 3 Posted December 13, 2012 Re installed and had the same problems. I am doing a system restore now. Share this post Link to post Share on other sites
Scottyy 3 Posted December 13, 2012 I did the system restore. Fixed the problem. Installed Microsoft updates. It made the problem come back. Did a second system restore and turned off automatic updates and flexi is working fine again. Basically if you run windows 7 do not install windows updates yet. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 14, 2012 LOL, that is probably why I don't have problems, I am back on XP.. 1 Share this post Link to post Share on other sites
Scottyy 3 Posted December 14, 2012 Unless they fix this soon I will be going back to XP pro back edition. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 14, 2012 I had win 7 for awhile, back to XP pro now and there it will stay. I can't think of a single reason to change. Share this post Link to post Share on other sites
prettybird 0 Posted December 14, 2012 I'm using XP. I've been trying to do a system restore but it won't let me for some reason so I guess I will try reinstalling flexi and see what happens. Share this post Link to post Share on other sites
dwp99 283 Posted December 14, 2012 Windows did an automatic update last night which caused some problems with Post Script type fonts and Flexisign. You can uninstall the updates and turn off automatic updates for your computer. Flexisign is aware of the problem. I read about this on another forum. http://www.signs101....ad.php?t=101766 Here is the procedure I used for Windows XP Step 1 Click the Windows XP “Start” menu and select “Control Panel.” Step 2 Click “Add or Remove Programs.” Step 3 Click to enable the “Show Updates” check box, located at the top of the window. This option displays all security patches currently installed on your system. Step 4 Select the update you wish to remove, and click the “Remove” button next to the item in question. If prompted for confirmation or further actions, follow the instructions presented on the screen to complete the removal procedure. For Windows 7 you can follow the link in the First Link above. Below is a quote from another website. We've taken several support calls today regarding an issue where PostScript fonts have stopped working within Flexi after last night's Windows update. We've heard reports that this is also happening to Corel users. The Windows update affected 64bit operating systems from XP to 8. SAi is currently working toward a solution, but until we find one, we recommend against installing this latest Windows update. Learn more about the Windows update here: http://support.microsoft.com/kb/2753842. If you have already installed the update and are having difficulty using Flexi, you can uninstall the update: http://windows.microsoft.com/en-US/w...move-an-update. __________________ Steph Stamm StephanieS@ThinkSAi.com www.ThinkSAi.com 1 Share this post Link to post Share on other sites
prettybird 0 Posted December 14, 2012 Here is a link to a corel draw forum where they are talking about it being the windows update also, myfonts.com sent it to me: http://coreldraw.com/forums/t/37077.aspx Share this post Link to post Share on other sites
MrMopar64 47 Posted December 15, 2012 The update you want to remove is KB2753842... That will fix the issue with flexi MM64 Share this post Link to post Share on other sites
