stitchesandsigns 0 Posted November 27, 2012 I'm trying to vectorize a maltese cross - see file - I've been playing with the speed, force etc on my copam 2500 - I've tried a new blade, adjusting the depth... I've tried to calls to support.. It seems the graphic might be too detailed? I've tried decreasing the number of nodes... I'm using Sure Cuts Alot Pro (just installed it - so I'm still learning) I have Corel, and Adobe. I'd like the cross to be solid - keep it simple - so it cuts better and looks good. I have to change each "G" number for every member... I've been cutting tests on oracal 651 - the end media is white reflective - ANY help, input, advice would be GREATLY appreciated... Thanks! Share this post Link to post Share on other sites
stitchesandsigns 0 Posted November 27, 2012 Sorry.... gwrking.pdf gwrking4.svg Share this post Link to post Share on other sites
mark-s 1,126 Posted November 27, 2012 It`s already a vector, just convert to eps. mark-s 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 27, 2012 If they are using Sure Cuts A lot, they need to keep it as a .svg file to import into the software. It won't import ..eps files yet. Are you just wanting the images and text removed from the cross? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 27, 2012 cross file, no images, post below, can't edit these files much, needs fixed Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 27, 2012 Maltesecross.svg Share this post Link to post Share on other sites
stitchesandsigns 0 Posted November 28, 2012 I really appreciate the input/help - when I open the file only half the cross shows - Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 28, 2012 I really appreciate the input/help - when I open the file only half the cross shows - I just imported it into inkscape.. this file imports fine. Are you importing and not opening? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 28, 2012 anyway all I did was cut away the images and text in the cross, pretty ez. Just select it and cut.. 1 Share this post Link to post Share on other sites
