twocents 0 Posted November 23, 2012 Hi Guys, I am going crazy with my vinyl cutter, Graphtec mk3000. I keep getting these really choppy cuts, and it will lift parts of the vinyl and cut through and it is just been a nightmare. I put brand new blades, and today I took it apart somewhat, cleaned the little wheels on top and did the best I could to clean it up without taking it entirely apart. It starts to cut good, and before the 2nd or 3rd sticker I get this mess. Any ideas what I am doing wrong here, or could it be the blade holder need replacing? I attached 2 pics of what is going on with the vinyl Any help would be madly appreciated! Share this post Link to post Share on other sites
vinylmotivations 140 Posted November 23, 2012 If you look at the strip under the blade, is it at all scratched or chewed up? Also if you're lifting vinyl, the pressure is probably too high or the blade is sticking. Try lubricating the blade with some 3 in 1 or dry graphite to make sure the blade is rotating inside the holder. Also, with the age of the cutter, the blade holder could possibly be bad and worn out. Using my machines, the pressure is often between 11-15 depending on thickness of the media. I can run as fast as I like without issue. Slower for smaller detail of course. Share this post Link to post Share on other sites
twocents 0 Posted November 23, 2012 OK let me try the oil, just drop it right in where the blade goes? The blades are brand new, but they are cheap, not from Graphtec, but I have used them before without problems. The cutting mat does have a few scratches but I dont think it is too bad. I tried to attach a few pics but they dont seem to be loading correctly. Thanks very much for your help Share this post Link to post Share on other sites
twocents 0 Posted November 23, 2012 And I have it on 16, I usually go around 14 or so but the test cut it was sticking so I had to turn it up a little more than usual. Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 23, 2012 what do you have the blade offset at? What cutting software are you using? With vinyl lifting, you could have too much blade exposed. I have the FC7000MK-75 and have never had to cut at force 16 for regular vinyl. Mine is at 11-12 force. I always cut slower, lol,, so I can read all the stuff in the forum and answer questions. Share this post Link to post Share on other sites
twocents 0 Posted November 23, 2012 offset is set at 0, dont think I ever changed that since I got it (used) Using AI and cutting master 2 Share this post Link to post Share on other sites
twocents 0 Posted November 23, 2012 Of course cant find any 3-1 oil, gonna run up to the store and grab some now, hope that works, that would be too easy Share this post Link to post Share on other sites
twocents 0 Posted November 24, 2012 The 3-1 seemed to have worked wonders, but still a bit choppy. These are designs Ive used before too with no problem so I know something is still wrong. What should the offset be set to? Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 24, 2012 zero 0 That is what mine is. I have seen most all Graphtecs have zero 0 Don't know about the real early ones.. Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 24, 2012 have you made real sure that there is no bit of scrap vinyl in the blade holder? It doesn't take a big piece to mess things up. Share this post Link to post Share on other sites
twocents 0 Posted November 24, 2012 Yes I checked that right away, nothing there, Im thinking maybe the blade holder, or the blades being after market perhaps? Thanks so much for the help, just w the oil alone it is working much better Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 24, 2012 Yes I checked that right away, nothing there, Im thinking maybe the blade holder, or the blades being after market perhaps? Thanks so much for the help, just w the oil alone it is working much better I have always used aftermarket blades.. I have owned my Graphtec since 2008. Never any problems. But maybe get some different blades. I will PM you where I get mine... Your welcome. Share this post Link to post Share on other sites
twocents 0 Posted November 24, 2012 Cool, I will try those out, I but the others from the same place, different seller. Thanks again and happy holidays Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 24, 2012 I hope it works out for you.. Happy Holidays to you also. Share this post Link to post Share on other sites
Dakotagrafx 7,184 Posted November 24, 2012 It's amazing what a few nicks int he cutting strip will do to make cuts not come out right - the CE3000 - is almost exactly like the ce5000 that is sold today. I have owned several of both and the only difference is the non MK2 version of the ce3000 doesn't have the optical eye for contour cutting. make sure you don't have any scraps in the blade holder also. If you want to try new blade holders the ebay cheap holders work great - I use them for my reflective blade and on my printer cutter I have different ones set up for different lam/ non lam so I don't adjust I just put a holder in already set for that material. On the blades I only use cleancut blades in both my graphtec and roland - start out with 30 percent less pressure and much less blade if you try one they are much sharper than the cheap aftermarket ones. They cut like the original graphtec steel blades but last even longer. mention the forum and get 10 percent off. PS I have had several graphtecs never had to set the offset to anything but zero . . . . . Share this post Link to post Share on other sites
MZ SKEETER 4,530 Posted November 24, 2012 If you see some gouges/nicks in the cutting strip, it has been said you can put a piece of reflective vinyl over it, to make it work. Or replace the cutting strip. Share this post Link to post Share on other sites
Dakotagrafx 7,184 Posted November 24, 2012 The older ce3000's are much much easier to replace the cutting strip than on the new ones - they use the butyl adhesive from he)) on the new ones - well worth the 22.50 for the new strip if it is damaged http://yhst-83279695798634.stores.yahoo.net/test511.html Share this post Link to post Share on other sites
