Maria Williams 0 Posted June 28, 2019 I recently tried to put a curly q monogram on a glass cup and no matter what I would do it would keep sticking to the transfer tape . Everything else I would use with the transfer tape would come out fine . I believe it may be because it was so small ? It was like 2x2 . But if that is the case , is there no way to put small stickers with transfer tape on anything? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 28, 2019 No mention of the brands of the vinyl or the transfer tape. or how high the tac on it. No mention of whether you washed down the cup with some alcohol before applying. Oils from fingers can stop from sticking. Did you squeegee the decal onto the cup.? Vinyl is applied by pressure. . Yes, You can apply small decals. on smooth clean surfaces. Share this post Link to post Share on other sites
