imsracing 0 Posted March 1, 2008 I need to know where the ground wire that is above the usb connection goes. I believe this could be my problem of it not communicating with my computer. Share this post Link to post Share on other sites
fourthsyde 0 Posted March 1, 2008 bigger picture??? i cant make it out from here Share this post Link to post Share on other sites
kenimes 42 Posted March 3, 2008 I can check in the morning when I get to the office. Share this post Link to post Share on other sites
imsracing 0 Posted March 4, 2008 I can check in the morning when I get to the office. Did you get a chance to look? Share this post Link to post Share on other sites
kenimes 42 Posted March 4, 2008 Should be a screw, right above where all the wires go into the frame. Connects to that screw. Should also be a yellow wire from the top of the motor to the same screw. Share this post Link to post Share on other sites
imsracing 0 Posted March 4, 2008 I have 2 wires that connect to the screw above the wire hole. One mounts the the lower screw on the feed motor and then the other one goes to?? Share this post Link to post Share on other sites
kenimes 42 Posted March 4, 2008 Mine is wrapped around the set of wires that has a black insulation around it....... Share this post Link to post Share on other sites
imsracing 0 Posted March 4, 2008 so it is going nowhere, correct? Share this post Link to post Share on other sites
kenimes 42 Posted March 5, 2008 so it is going nowhere, correct? Yea, pretty much nowhere, from what I can tell. Share this post Link to post Share on other sites
imsracing 0 Posted March 5, 2008 I took all the covers off to access the motherboard, power center, and switches and i see nothing loose, broken, etc. What is the next step? Share this post Link to post Share on other sites
kenimes 42 Posted March 6, 2008 Even though everything looks to be in place, push down on each connection anyhow just to be sure. Put it back together and then is if it connects. Share this post Link to post Share on other sites
imsracing 0 Posted March 7, 2008 When i checked them, i pushed them down to make sure they were in place and still no luck. Share this post Link to post Share on other sites
kenimes 42 Posted March 7, 2008 We could send you the USB port to try and replace. Could you PM me your shipping info.? Share this post Link to post Share on other sites
