htrowrod 1 Posted October 19, 2012 I purchased a used machine and have Flexisign 8. I have cut out a few things and it worked really well. I have this one file and it starts cutting and at about 18% the cutter and software stop and the cutter head goes back to home and sits there. Only on this one file so far. Any thing to try? Bruce 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 19, 2012 You don't state what machine, put would guess it is on a USB connection. Put it on a Keyspan adapter,,and be done with it. If on a stand, ground the cutter to the stand, if static, put some dryer sheets in vinyl roll. Also. If you raise, the blade up so that it does not touch the vinyl while cutting... will it complete the project? If so, most likely static. Share this post Link to post Share on other sites
htrowrod 1 Posted October 20, 2012 I have a Rohs(chinese) cutter. Yes, it is hooked up with a usb connection. I took the knife completely out and it still does the same thing. I think there is something with the file. Bruce Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 20, 2012 serial is the way to go .. You could also post your file for someone to look at. Share this post Link to post Share on other sites
htrowrod 1 Posted October 20, 2012 I would be willing to PM the file to someone. I wouldn't want to post the file and have it go viral. Bruce Share this post Link to post Share on other sites
