aguilar
FLEXI SIGN PRO AND SIGNMAX (REDSAIL) VINYL CUTTER WORKING TOGETHER
OK I GOT IT WORKING woohoo.gifusing usb A BIG THANKS GOES TO
Snapper
FOR SHARING THE DRIVERS
STEP BY STEP INSTRUCTION
1 DOWNDLOWDED THE VE LXi 10.0.2 file from sign warehouse
2 look inside the folder and find the (PROG) folder click on it an find the (usb
driver folder)
3 COPY the (VINYL csm file 35kb ) note that in the new file on the signwarehouse
page
there is a similar one call "vinylUPDATED" THIS FILE IS ONLY 23KB BECAUSE
THE FILES FOR THE REDSAIL(Rseries CUTTER AR NO LONGER ON IT ) not sure why.
4 copy the (VINYL csm file 35kb )
5 go to wer you have flexisign install open the folder of flexisign pro, find
the folder name (OutputDrivers) and paste it there and close the folders
6 open the VE LXi 10.0.2 file and click on the picture of the (Rseries)
7 CLICK ON INSTALL CUTTER DRIVERS a black window will apper whit some letters
saying installing driver
8 go to star rigth click my computer click properties, click device manager, go
to ports click on the + sign to open all ports, RIGTH click on USB serial
Port(COM4), click PROPERTIES, Port Settings CHANGE THE (Bits per second from
9600 to 4800) flow control to NON and click OK
9 NOW OPEN FLEXISIGN PRO open any vector art file that you will like to cut and
click cut
10 CUT/PLOT WINDOW AND PRODUCTION MANAGER WILL OPEN on the Cut/Plot window click
setting is right next to properties
11 wen you click setting the PRODUCTION MANAGER window will pop up, now on the
PRODUCTION MANAGER window click setup then click ad setup a window whit Manufacture and model names of cutter will apper (find the vinyl express and on
the model name click the one you got i use the (R31) AND CLICK NEXT
12 A WINDOW WILL POPUP (SET UP PROPERTIES) here you will name youre cutter (like Redsail cutter or SIGNMAX CUTTER, Rseries, ETC...and in the same window click the port icon and find port:COM4 IN SETTINGS
BITS PER SECOND:9600
DATA BITS:8
PARITY:None
STOP BITS:1
FLOW CONTROL:Xon/Xoff
HARDWIREDS : ONLY CHOOSE RTS/CTS
click APPLY and ok
now click send or cut and youre vinyl will be cut :)
if i miss something im so sorry, but this is wath work for me
(im using A SIGNMAX CUTTER, WINDOWS XP, AND FLEXISIGN-PRO 8.1v1 WHIT a USB
CONECTION )
you are welcome to edit or CHANGE this POST to help others.
Just keep an eye on those drivers... I use the same ones on my R31 and after a few months they all of a sudden went berzerk... It wouldn't cut the design properly leaving parts out and random shapes and lines within it.... If you look on their forum and search you will see this issue time and time again.... If you have the option I would go to a Serial... Also on the usb the on screen controls for contour cutting never worked properly either.
agguilar, I just wanted to say thanks, your how-to saved my ass! I don't know why they decided to remove the r24 driver in the vinylUPDATED csm.. idiocy. For anyone looking to resolve getting their Redsail cutter working with Flexi 8.1 Look No Further!
Thanks again!  B)
I am lost on #6 ..
I open the VE LXi 10.0.2 file and I see no picture of the  Rseries
