34Ford 7 Posted September 24, 2012 Yea that was me over on t-shirt forums talking about the bad roll I bought. Siser had it replaced once they confirmed the lot number that is inside the tube. But yea, the bad stuff would lift just peeling the clear carrier off and one time I opened the press and it lifted. The replacement roll was a dramatic improvement. I dont pre wash my Gildans either. Share this post Link to post Share on other sites
BrianMaruska 12 Posted September 28, 2012 After getting my press in the mail today and making some shirts tonight, we are allllll good! Share this post Link to post Share on other sites
BearlyRich 167 Posted October 1, 2012 Glad to hear it's all working for you now! What did you get for a new press? And what was your old press (sorry if was mentioned, just curious)? Share this post Link to post Share on other sites
tonyfatz9 0 Posted October 1, 2012 I have been using siser for couple years now. I use 320 setting and press twice at 15 secs each . When I first started I was doing the min. time to press and had peeling but havent had a problem since. Share this post Link to post Share on other sites
vinyliscoolio 1 Posted December 25, 2012 I always use 305 for 15 seconds and never have any trouble. I also do a 5 second pre-press to remove moisture from the shirts at a medium pressure. One time the knob set screw for the temp adjustment knob came loose on my stahls press as I was adjusting it one day and when I turned the indicator back to 305 the actual shaft on the adjustment pot did not move. I thought I was at the correct temp from the visual pointer but I was not due to the knob coming loose. If you have a manual temp adjustment knob like this you may need to confirm your temp. Once I noticed the loose knob I called stahls and they sent me some temp calibration strips and I was able to clamp the press down on the strip and read the actual temp and set my knob to match it. Probably not your problem, but I bet this has happened to at least one other person somewhere, so I thought I should mention it. I would definitely try and find some way of verifying the temp you are actually producing from the press. Share this post Link to post Share on other sites
Carmigirl 7 Posted January 23, 2013 Didn't read thru all comments but make sure you always prepress for about 6 seconds to get moisture out Share this post Link to post Share on other sites
mr300s 1,272 Posted January 23, 2013 If you had you would have read this My name is Yoann Giorsetti and I am the Director at Siser. Having washed your shirt will not have any impact on your transfer ability. Pre heating makes it easier to work but it's not a necessity working on T-shirt. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 23, 2013 what type of press are you using - have you checked the actual temp in different areas around the platen? Share this post Link to post Share on other sites
TT57 135 Posted March 28, 2013 it has been mentioned to check the temp of the press. I did read about strips above. Where do you get these? Since I don't have a Stahls I am sure they won't provide mine as above. How else would I check. ? thanks. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 28, 2013 it has been mentioned to check the temp of the press. I did read about strips above. Where do you get these? Since I don't have a Stahls I am sure they won't provide mine as above.How else would I check. ? thanks. just get a ir thermometer to check the temps in the different areas of the platen http://www.newegg.com/Product/Product.aspx?Item=9SIA1NV0KV7534 Share this post Link to post Share on other sites
