CarterMarkham 18 Posted September 15, 2012 It's like when you touch aluminum, you get black all over your hands...hard to explain. When they blade holder comes in contact with the vinyl during cutting, it leaves some black ish residue on the vinyl. It does rub off but its something I would rather not deal with. (Yes I have cleaned it) Cutter is LaserPoint II Share this post Link to post Share on other sites
BannerJohn 1,324 Posted September 15, 2012 decrease the pressure. The blade holder really shouldn't touch the vinyl. 1 Share this post Link to post Share on other sites
CarterMarkham 18 Posted September 16, 2012 I am at 500g, if I decrease it, it still touches the vinyl but doesn't cut good. I have adjusted the blade so it cuts as the instructions at start.uscutter.com suggest. Share this post Link to post Share on other sites
Three Springs Design 0 Posted November 8, 2014 CarterMarkham, did you ever find a solution to this issue? my cutter is doing the same thing. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 8, 2014 CarterMarkham, did you ever find a solution to this issue? my cutter is doing the same thing. He hasn't been on since August 2013......Try backing the force off, on your cutter. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 8, 2014 If you set your blade depth correctly the holder should be just barely off the vinyl and allowing the blade to go through and just scratch the waxlike product on the carrier paper. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 8, 2014 correct way to set blade depth. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. Share this post Link to post Share on other sites
CarterMarkham 18 Posted November 8, 2014 I'm still around. I sold it and bought a graphite. 1 Share this post Link to post Share on other sites
