constricted 27 Posted September 14, 2012 Hey guys, I have a Craft Robo CC330L-20 that I've been using the factory blade for around a year and it looks like I'm in need of a replacement blade. I only used the plotter for cutting vinyl (mostly oracal 651) I have no idea what replacement blades to get or part #s or anything. It would be greatly appreciated if you more experience users can give me some guidance here Thanks, Matt Share this post Link to post Share on other sites
lizzylou 11 Posted September 14, 2012 Hey guys, I have a Craft Robo CC330L-20 that I've been using the factory blade for around a year and it looks like I'm in need of a replacement blade. I only used the plotter for cutting vinyl (mostly oracal 651) I have no idea what replacement blades to get or part #s or anything. It would be greatly appreciated if you more experience users can give me some guidance here Thanks, Matt .Check your Graphtec user manual. Share this post Link to post Share on other sites
mb20music 760 Posted September 14, 2012 Are these what you use? http://www.ebay.com/itm/1x-Blade-for-Wishblade-Silhouette-Craft-Robo-Graphtec-Cutting-Plotter-47-Degree-/230830659199?pt=LH_DefaultDomain_0&hash=item35be94567f Share this post Link to post Share on other sites
constricted 27 Posted September 14, 2012 .Check your Graphtec user manual. I already checked, the Graphtec user manual doesn't have any part #s listed Share this post Link to post Share on other sites
constricted 27 Posted September 14, 2012 Are these what you use? http://www.ebay.com/...=item35be94567f that blade looks identical to what i'm currently using.. the factory setup has a black blade holder and 3 caps (blue yellow and red) that vary cutting depth (1mm, 2mm, 3mm) Share this post Link to post Share on other sites
mb20music 760 Posted September 14, 2012 Looks like USCutter doesn't sell the blade seperately, you have to buy the blade holder, blade and the caps. http://www.uscutter.com/Graphtec-Craft-ROBO-Silhouette-Blade-Set-GRPROBOSET Share this post Link to post Share on other sites
constricted 27 Posted September 15, 2012 Looks like USCutter doesn't sell the blade seperately, you have to buy the blade holder, blade and the caps. http://www.uscutter....-Set-GRPROBOSET that looks to be a perfect match.. thanks can i use the other blades you linked to? i don't think i need the blade holder and caps since mine are in good shape (http://www.ebay.com/itm/1x-Blade-for-Wishblade-Silhouette-Craft-Robo-Graphtec-Cutting-Plotter-47-Degree-/230830659199?pt=LH_DefaultDomain_0&hash=item35be94567f ) Share this post Link to post Share on other sites
mb20music 760 Posted September 15, 2012 Yes you can, hopefully you have an eBay and Paypal account, otherwise you will need to set them up. Also in case you didn't notice the blade comes from China so it will probably take a few weeks to be deilvered. Share this post Link to post Share on other sites
constricted 27 Posted September 15, 2012 I have an ebay and paypal accounts so that's no problem...Thanks again for your help! Share this post Link to post Share on other sites
edge 67 Posted September 15, 2012 First thing I did several years ago was replace the silly plastic CraftRobo colored cap blade holder with an Accucut blade holder for conventional blades with with true adjustable depth. While I haven't seen this brand advertised anywhere recently, there are similar set-ups on ebay for even less. Have you considered this? Share this post Link to post Share on other sites
constricted 27 Posted September 15, 2012 would this work ? http://www.ebay.com/itm/Wishblade-Silhouette-Craft-ROBO-CAMEO-Original-Blade-Set-/261079358764?pt=US_Die_Cutting_Machines_Dies&var=&hash=item826b3b087d Share this post Link to post Share on other sites
edge 67 Posted September 16, 2012 would this work ? http://www.ebay.com/...=item826b3b087d Is that the ratcheting blade holder assembly that one disposes in it's entirety when the blade is no longer usable? While I have not used anything like that, I understand it will work. I hesitate to link to another seller other than US Cutter here, but if one does a search for SGS Silhouette Metal Blade Holder they will find an adjustable metal blade holder for $29 that uses common GraphTec .9mm blades Share this post Link to post Share on other sites
constricted 27 Posted September 16, 2012 i'm not sure about the one i linked to.. i did find the SGS Silhouette Metal Blade Holder though.. i'll probably order one of those soon Share this post Link to post Share on other sites
