tthorn 2 Posted September 4, 2012 Maybe I'm just missing this? But I can't figure out why. I'm trying to cut one image 76 times. So 76 tiles correct? I addjusted the legth of it to fit all the tiles. For a trial run, I tried 3 tiles at first. After the first tile, the second tile created a huge line through the second design, and didn't cut out the text. Fail. So, attempt #2. Cut the design once, have it advance 0.20 after cut, recut design. Didn't work. The vinyl feeds backwards, and does a double cut over the design before that. Am I grounding this wrong? Is there an option I'm missing? I need to get these shirts out ASAP, and keep having this problem. Any help is appreciated. Thank you. 2 Share this post Link to post Share on other sites
Jay2703 704 Posted September 4, 2012 Adjust the number of copies, check only the "Weed Each Copy" option and set the distance between copies that you want. http://screencast.com/t/TnaErtiAt Jay Share this post Link to post Share on other sites
tthorn 2 Posted September 5, 2012 Adjust the number of copies, check only the "Weed Each Copy" option and set the distance between copies that you want. http://screencast.com/t/TnaErtiAt Jay Thanks for a response. I did what you said. Tried another trial with 3 tiles. First tile cut out fine, it skipped the second one and went to the third one. Then after completing the 3rd one, went to the second one and only cut the top portion of the design. It went back to third one after cutting the top portion, and recut the third one... AHHHH! Share this post Link to post Share on other sites
Jay2703 704 Posted September 5, 2012 Check your settings. See mine below. What connection are you using? USB, Serial? Share this post Link to post Share on other sites
tthorn 2 Posted September 6, 2012 Check your settings. See mine below. What connection are you using? USB, Serial? I have that all set the same. I have serial connection. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 6, 2012 how big are these designs? and are they detailed? And what cutter are you using? Have you tried using the FREE version of Signcut, that comes with new cutter purchases? To see if it's the software or the machine? Share this post Link to post Share on other sites
Mx2 11 Posted September 6, 2012 You should upload your file here so someone an download it and see if there are issues with the file Share this post Link to post Share on other sites
Jay2703 704 Posted September 6, 2012 What cutter do you have? Share this post Link to post Share on other sites
