HeavyD 6 Posted September 3, 2012 I have a Pcut CT630. everything seems to work, but I can only adjust "cutting speed" from 50 to 80. everything else adjusts right, have adjusted the press - no probs. i sthere a fix for this? 3 Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 3, 2012 Cutting speeds are usually registered in mm/s and the slowest speed I can access on my SC/Liyu is just 100mm/s and I normally run at 800mm/s (top speed) Share this post Link to post Share on other sites
HeavyD 6 Posted September 3, 2012 according to the manual the adjustment on the cutter(not computer) should adjust from from the manual: " Cutting speed In speed setting mode, press “+”or“-”to adjust cutting speed, high speed is suitable for cutting big characters or image, while low speed is suitable for exquisite small character or image. 10-shift speed is available for your choice: 10 → 20 → 30 → 40 → 50 → 60 → 70 → 80 " Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 3, 2012 Pcuts used to have different models with different settings for force. Newer models had the higher settings 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 4, 2012 He is not talking about downforce here, but rather the speeds. Apparently, there is a glitch that prevents his machine from going any slower than the highrange 50-80 (ostensibly, 500mm/s - 800mm/s) What happens when you are already cutting, and try to adjust? Share this post Link to post Share on other sites
HeavyD 6 Posted September 4, 2012 He is not talking about downforce here, but rather the speeds. Apparently, there is a glitch that prevents his machine from going any slower than the highrange 50-80 (ostensibly, 500mm/s - 800mm/s) What happens when you are already cutting, and try to adjust? you cannot adjust anything while its working. when its working it says waiting, and when its done it says online. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 4, 2012 He is not talking about downforce here, but rather the speeds. Apparently, there is a glitch that prevents his machine from going any slower than the highrange 50-80 (ostensibly, 500mm/s - 800mm/s) What happens when you are already cutting, and try to adjust? your right, my error..thanks, It was the speed that was changed, to higher numbers. Share this post Link to post Share on other sites
